if i buy new/same exact cc injectors do i need a retune???
If it's the same brand and same size, the you don't need to retune the ECU. If different brands, then it depends. Do you have a wideband with which to monitor AFR's?
Just log it and compare the fuel trims and make sure they're the same, but if they're different, you might need a little adjustment, but nothing major.
