Backfire problem...
Question with which wires to go with? People are having problems with the Magnecor 8mm and 8.5mm cause of fitment issues. I heard its best to go with new stock or ralliart wires. What's the good word?
So after putting in the new plugs i did not torque them down to spec with an actual torque wrench. I torqued them down to factory spec 18pounds. That was the culprit. I no longer have any issues with a backfire or hesitation. Thx for everybody's help and suggestions. I still plan on swapping out the wires for mileage reasons...
Two things, it really isn't a good idea running WOT without knowing your AFR if fuel maps were set for methanol, you can melt down the engine at 18psi running stoich at WOT. Also, a loose spark plug is an easy way to send engine parts through the block. Without proper torque the plug has no means to transfer it's thermal energy to the head. It may become hot enough to preignite the air fuel mix during the compression stroke, devistating! Keep them torqued
BTW, my son say's hello to everyone
jorge mr
22
Nov 9, 2018 05:05 AM
sleet
31
Oct 16, 2006 01:23 PM
zlancer
Lancer Aftermarket Forced Induction Tech
Jun 30, 2002 09:23 PM
