ARP L19 head studs 1+1... what to TQ???
Picked up some L19's and arp lube. I'm about to install them just using the 1+1 method. After searching I had a hard time finding much info on the L19's and most everything else I read regarding the regular arp head studs was anywhere from 70-90lbs. So what's the general thoughts on what it should be?
Btw I k ow many are anti 1+1, but I'm not asking for advice on that subject, just tq specs tia.
So I set the tq wench to 90lbs and busted a crapsman socket onthe first one... So after going and getting a new socket I just kept them all at 90lbs cause I had to drive my car to work this morning and didn't want to risk breaking another socket.. This is the 2nd socket I have busted too.. Is this common?
Use an impact socket (Black) don't use chrome sockets they are not as strong, also clean them with Brake Clean, you don't want any dirty tools in your clean engine.
Usually i re-torque after a few heat cycles.
