Tranny Oil and TC ,Help Asap!
Old May 14, 2009 | 12:14 AM
aguita's Avatar
I know that you guys recommend to stick with OEM...But I need my car running b4 Sat and here in my country I cannot find the OEM or AMSOIL..
The Question Is..Can I use a Brand of Oil Like Texaco Havoline or Something on those lines??
I have Used Motul but is HELLA expensive here in my country..
So what Grade Do you recommend for the tranny and TC to stick using a brand like the above ones?!
This is a temporary Oil Till my diaqueen Arrives hopefully by next week or later!
Old May 14, 2009 | 12:19 AM
sekula's Avatar
I have always used Redline in my transmission, transfer case, and rear diff. Never grinds or anything and love it - smooth shifting!
Old May 14, 2009 | 07:28 AM
dtuned's Avatar
Liqui-Moly, and it is available in DR. Just go in and ask for the same weight oils as specified by Mitsu for the gearbox and for the TC.
Here's the contact I googled for you:
Castalosa, S.A. Las Colinas DOM-Santiago
Ave 27 de Febrero 52,
Tel: 001809 575 1942
Fax: 001809 576 3755
I use Liqui-Moly in my EVO VII.
Old May 14, 2009 | 08:36 AM
aguita's Avatar
MAN! you rock..I forgot that place ..I have bought BMW parts there and they sells Oils too!...
Ironic is that they are next to a mitsubishi Parts only dealer !!
hahaha
Old May 14, 2009 | 09:04 AM
dtuned's Avatar
Just glad to help, and there's no need to be waiting around for Mitsu stuff if something is readily available I use Liqui-Moly bcuz that stuff is great for countries that have higher than ambient air temps like the Middle East and I am sure the Caribe is just as hot. Yeah that is quite funny that they are located next to Mitsu. At least now you can go in and price compare, and I am sure that Liqui-Moly has all the stuff you need so that you don't have to bust your cash for Motul, which as you said is quite costly.
w8less1der
44
Feb 1, 2018 06:37 PM
JGNERAEVO9
Feb 5, 2016 06:13 PM
5LEEPERISAH23I
37
Apr 12, 2010 06:06 AM
ej257gd
Mar 23, 2008 07:33 PM
lilgunz
Mid-Atlantic Region
11
Feb 28, 2008 07:18 PM
Quick Reply: Tranny Oil and TC ,Help Asap!
