Help!!!! Exedy Twin HD ?
Old May 15, 2009 | 10:47 AM
Ev0ikon's Avatar
Question Help!!!! Exedy Twin HD ?
So after 2 years of being down (blown engine and the second child kicked my butt and ate all my time my car is ready to be back on the road.
Last night I went to put and put the clutch in (used Twin HD with new friction plates).
What I don't remember is how tight the assembly is after the final bolts are torqued down. I could not spin the plates with the attached allignment tool. I triple and quadruple-checked with Exedy diagram. Plate A goes outside close r to the tranny and plate B is closer to the engine. They are turned properly per markings on the plates to face the transmission. Once I removed the alignment tool the entire assembly is so rigid I thought I must have jammed something.
Could anyone please verify if it is supposed to be like this. It's been a long while.
TIA
Old May 18, 2009 | 09:27 AM
chu's Avatar
chu
Are you talking about the allen bolts? If so, I recall 23lbs, star pattern. Also, did you use Loctite on the flywheel bolts, its very important!
Old Jun 8, 2009 | 09:10 PM
zlthomason's Avatar
i havent put one on yet rebuilding now but when i took it off it moved pretty freely but not a hundred percent sure on install but would imagine it isnt suppost to be hard to turn
Jul 13, 2012 07:17 AM
JEP
Oct 4, 2010 03:48 AM
EVOLV3D
May 21, 2009 07:46 AM
uae75
Feb 22, 2008 05:44 PM
Evo23IG
Jun 29, 2006 12:13 PM
Quick Reply: Help!!!! Exedy Twin HD ?
