How to keep the crankshaft pulley in place.
Im trying to remove the crankshaft pulley bolt but I cant get the pulley to stop moving with it. I searched some stores for a pulley holder but couldnt find one. I dont have air tools and my friend with an impact gun cant come by til friday and I want to have this done alraedy. What is a good way to keep the crankshaft pulley in place. Or where is a store I can but a universal pulley holder.
See this pdf for how to set it up.
https://www.evolutionm.net/forums/at...-how-pg-1a.pdf
If all else fails put the timing belt back on and spin the motor over by hand twice to make sure you don't hit a valve then use the above method.
Sorry bro
I just loosened up the belt tensioner and took the belt off. I wish I would have known of this technique beforehand though thats for sure. Ill probably just wait for the torque gun if that fails then I guess I have no choice but to put the t-belt back on.
Thanks for the info.
Since you probably have the cover off already taking the cams out will prevent the valves from hitting the pistons. I would still suggest manually turning over the engine by hand with the cams out to test for interference before trying to bump the starter.
i was originally just going to replace the cam seals but then I found out that my crank sensor and crank sensor blade were damaged so I had to replace those. Ill probably take out the cams and use this technique. Im still just going to wait on the torque gun first before making more work for myself.
Not to go off topic, but why are you taking the crankshaft bolt off? You can take the pulley off without taking the crankshaft bolt out.
btw...I have a badass IR impact gun that has like 650 ft lbs torque and it wouldn't break mine loose.
like I did it without the impact gun, actually 450ft/lb wouldn,t do it. I'm guessing your engine is out,well I had to put two flywheel screws on and a pry bar between the two of them (prying against each other) then have some one hold the pry bar to hold the flywheel side steddy, you on the other side with the brake bar start turning the bolt. Make sure you dont bend the fly wheel screws, it took a little bit but it came right off.
jtcarstens
Oct 9, 2014 11:59 PM
