Coolant Leaking Out back of Block
1 Post
I noticed some coolant leaking from what I thought was from the weep hole on my water pump but after further investigation we have found some coolant leaking from under the intake manifold. We recently installed a Buschur stage 3 head and used a stock head gasket with arp headstuds torqued to 95ft lbs like Buschur reccommends for their head. After the car was tuned is when I started noticing the leak. I have no signs of a headgasket leak at all. No oil to water mix or vise versa. Also I am not burning antifreeze either. My friend things there are some freeze plugs back there that could be leaking. Is that what it could be or what else could be the cause of it on the back of the block?
i think i have the same problem but i see some anitfreeze on the front of the motor rite on the head gasket
does anybody have pictures of these core plugs and where there located
Tw3NTy0n3
13
Jun 29, 2016 11:09 AM
lghtngyello03
Mar 19, 2016 04:25 PM
Wheatley
Sep 20, 2009 09:42 AM
mugen777
Oct 31, 2008 07:07 AM
