mitsu crank/ flywheel bolt patterns
hey guys,
i'm looking for a crank to use as a tool for balancing my flywheel and pressure plate. you guys who have worked on mitsubishis all you life may be able to tell me if any engine models beside the 4g63 share the same flywheel to crank bolt pattern and center bore dimension. that info would really help me to find a crank core at a reasonable price in a reasonable amount of time. is there a thread or site to visit with this info?
thanks all
thanks all
so, by searching i've found that evos since '92 have seven bolt cranks (thank you wikipedia). i'm still unclear as whether there are any non-turbo or eclipse versions with seven bolt cranks.
Blacksheepdj
Lancer-Mirage Compatibility Forum
107
May 1, 2015 06:21 AM
ehb403
Sep 14, 2014 04:34 AM
Svendiesel
24
Jul 30, 2013 09:23 AM
