From VIII to IX turbo, parts that are needed?
I'm sure this has been discused before but do you think I could find it anywhere... nope. I guess my biggest question is are there any differences between the VIII and IX exh. manifold, do I need to pick up a IX manifold to install a IX turbo on an 8. Also assuming I need an "install kit" with a j pipe and oil lines? Anything else?
Manifold is the same. You'll need different install parts if you're putting it in an VIII. FP has a kit that shows the parts you'll need, just for reference.
http://store.forcedperformance.net/m...Lancer-TurboHW
Some people have interference problems with the VIII outlet pipe and the starter hot side. You should check carefully for that issue if you're not using a IX outlet pipe, as it can short and cause you serious misery...
A new oil line is also a very useful part, as some of the existing lines have corrosion in them, which breaks off and damages the bearings in the turbo...
All of these parts plus the gaskets etc are in the FP kit.
10isace
Nov 25, 2011 08:56 PM
M1 Autosport
Mar 22, 2010 03:26 PM
M1 Autosport
Mar 22, 2010 09:39 AM
