View Poll Results: Which turbo would you choose
FP Red
27
45.00%
FP HTA 3582
3.33%
FP HTA 3586
15
25.00%
PTE 6262
16
26.67%
Voters: 60. You may not vote on this poll
Which Turbo would you choose
Old Jun 14, 2009, 11:02 AM
dambikeracer's Avatar
I have a Red that I have not put on yet but am already thinking of going bigger.
FP Red
FP HTA 3582
FP HTA 3586
PTE 6262
Old Jun 14, 2009, 12:00 PM
Could I also get some feed back from anyone running these turbo's? Pros, cons, spool RPM on 2.0L.
Old Jun 14, 2009, 12:03 PM
jusa4bngr05mr's Avatar
Go biggg. can I have your red. lol
Old Jun 14, 2009, 12:39 PM
mini_evo's Avatar
I say do the FP HTA 3586R. From everything I have read about the HTA 35 turbo's, the .86 spools 2-300 RPM later than the .82 on a stock 2.0L. it Should be at full spool around 3600 RPM.
And I dont know **** about the PTE 6262 other than it is a Frickin' MONSTER of a turbo and that it is to small for a 2.0l to be effective.
Old Jun 14, 2009, 01:14 PM
ScorpionT's Avatar
3586 and 6262 are pretty evenly matched, but the 6262 is better priced. The 3582 wont make as much power but will spool a bit quicker. If you wont be tuning for 700+whp but still want 500+ go with either the 3582 or Precision 6062.
Old Jun 14, 2009, 01:31 PM
skyblas's Avatar
3586 would be the better choice if u want bigger power with overall drivability
Old Jun 14, 2009, 01:35 PM
EvoAlex48's Avatar
hta 3586
Old Jun 14, 2009, 02:17 PM
Ted B's Avatar
Two things for you to consider:
(1) Whatever these turbos spool at sea level means little to you. They will all spool slower in Denver (at altitude). Think about how that affects your driving habits.
(2) The FP Red is capable of spooling faster than any larger turbo, and when configured properly, one would have to make a good deal more power with a larger turbo to catch up to the Red.
The power potential of the Red is making it increasingly difficult to justify larger turbos for street use.
Old Jun 14, 2009, 02:27 PM
EVILBLOODBROTHA's Avatar
I'd have to say it's all about the ams turbo systems that they offer. Like the 850 thats a sick setup
Old Jun 14, 2009, 02:31 PM
DBallz's Avatar
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I just installed the red and my numbers very high for pump gas.
Check the graph
https://www.evolutionm.net/forums/ev...mp-469whp.html
Old Jun 14, 2009, 02:32 PM
rodent's Avatar
For the money, the 6262 is hard to beat. AMS is running 8's with that turbo.
Old Jun 14, 2009, 02:33 PM
VETTE_50_TH's Avatar
Never buy a PTE ball bearing turbo unless you want to be replacing them every 10k. I come from the disregarded land of dsms, and i have PROOF these BB turbos **** the bed quite often. Stick to a FP turbo or a MHI turbo. FP def. know their ****, and their turbos are VERY nice. But im sure you know that.
Old Jun 14, 2009, 02:35 PM
CO_VR4's Avatar
Read Ted B. above.
Power under the curve says RED. Up here, you'll add a few hundred RPMs to spool, and unless you have a built motor and can use an expanded powerband like 5000-9000, the larger turbos will not spool very long before you hit factory redline.
Old Jun 14, 2009, 02:52 PM
murrtownevo9's Avatar
FP red FTW
Old Jun 14, 2009, 04:08 PM
rodent's Avatar
Good to know. Nobody mentioned this in the thread I have going:
https://www.evolutionm.net/forums/en...262-turbo.html
I'm going with the FP 3586.
Quick Reply: Which Turbo would you choose
