Clutch Slips When Tightening Crank Bolt
Hey guys, I just want to run this by your before I put the rest of my car together. I need to tighten the main crank bolt, so I put the car in gear expecting that to hold enough to tighten it, but the clutch just slips. I took the trans inspection cover off, and when in gear the main shaft does not rotate when I rotate the motor, however it does when the trans is in neutral, meaning the clutch must be slipping when it has load on it. This concerns me because it does not take much force at all to make it slip. I've never put a clutch in before, so I don't know if it is normal, but it sure doesn't seem right.
The clutch is a new SPEC Supertwin.
Let me know what you think.
Thanks.
Thanks.
make sure all of the cover bolts on the clutch are tight, and you might double check the bolts on the PP springs as well (if you can get to them without pulling the transmission). being a brand new clutch it is possible that it will move, but it probably should not. The throwout setup isn't applying any pressure on the clutch, is it?
Are you saying your car does this, or just clarifying that the flywheel would spin? If just clarifying, I understand that the flywheel would spin, but I would think the rest of the driveline should spin too, and its not. The 2 rear tires are on the ground, but thats irrelevent because I can look inside the tranny, and the main shaft only spins when I turn the motor over in neutral. when in gear, it does not spin.
anthonypazsd
134
Jan 19, 2024 11:48 PM
Darkn3s
Sep 11, 2013 01:53 PM
bruce988jl
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 23, 2008 02:24 PM
