Kevin@MellonTuning's Stock Evo IX Build with pics and DLL dyno numbers
#248
Yeah a few... My Alt-map switch finally came in so I hope to get that installed this weekend along with my new TB shaft seals that I ordered from Mil Spec. Also, Mellon and I are planning to head to the track Friday night if the weather holds up. Looking forward to a 9 second pass out of his evo and an 11 second pass out of mine
Wish us luck!
Wish us luck!
#250
Haven't touched my BOV. Boost is falling to 20-21 psi by redline. Hope the shaft seals will help some. I know when we boost leak test they leak bad at 14psi I can only imagine how bad they are leaking at 28. APS twin vent might be necessary soon.
#252
sweet im right down the road here in jackson tn....
def. not a far drive to get some good work done on the evo. thats for sure but im still new..
what do you mean crush the bov...im guessing its where boost leaks are known to be at on an evo..?
but what is crushing
#255
Well since the last update I've been to the track twice. On e85 I ran a best e.t. of 11.91 and a best mph of 114 out of 3 runs. Went to the track this past Friday and ran a 12.33 @ 109 on 93 oct. We also replaced my TB shaft seals... It was my only leak! Mellon and I were both amazed at how well its sealed up now. We still need to see if its affected the tune... Should get around to that soon.
