Timing belt noise.
Timing belt noise.
Well after I install my new timing belt this past weekend.
Start-up was perfect, idle great, drive smooth, and boost fine.
but,..( yeah I know..) there's slightly more noise from the timing belt that happen only at idle..
Do you think that I put too much tension on the belt? should I be concern?
anyone experience this with theres??
I'm about to re-do, re-tension my belt. but if Its normal I might just leave it alone.
any info is greatly appreciate. C
Well what kinda noise is it? From my personal experience of timing belts, as working for toyota, belts that sounds like they are whining are tight, and belts that sounds like its flapping is loose. Kinda hard to explain but, when you feel the tension of the belt between the two cam gears, there should just be enough to move up and down about about a few cm's or so. Almost like if there were anymore tension right there you would know right away that its too tight. Might sound retarded but im not sure of exactly how to say it. Anyways hope that helps in any way!
