Lesson learned on Boost leak tests
Even if you think your car is running great and dont see any problems, do a boost leak test every once in a while!
I tried my first last night and the car runs pretty damn good, but I found a GAPING leak at my IC pipe to the turbo side of the IC. Like sooo bad that putting my hand over the coupler was like spraying a can of compressed air directly into my hand. Sounded like my turbo at full spool. lol
I cant wait to see how much power this will bring back to life. This was only at 20psi too. Who knows how long its been like this.
Will fix this and see if there are any more down the line, but important realization learned for sure.
Hmmm, I did a boost test last night and maybe you guys could help me answer a few questions.
1) What are you guys boost testing up to?
2) Are you getting any boost leaking out of the oil cap (I believe that its boost coming around the crank case)?
3) How much boost should you test for if you plan on say oh.... 30-32lbs stock turbo?
I tested 20lbs holding with good results, beside the air escaping form that little vaccume line coming off the head that the little k&n filter goes over.
i initially tested for 20psi to see what would happen. Im going to test for like 25-30 once I fix this big one
Are you plumbing into the turbo and shoooting air in there?
I never had any air ever come out of the valve cover. I think it depends on your pcv/vent setup maybe?
IE - there is no line on the Valve cover breather you are reffering to since the MAF pipe is already removed in order to gain access to the turbo inlet.
I can make small changes myself though if it runs lean, but it wont be bad enuff to make a huge affect. My tune has been looking richer lately. I am wondering if this was like this during the tune , or when i took the manifold and all the other stuff off after the tune to fix and exhaust leak at the mani. (it prob happened then)
There are easier ways for air pressure to escape than to try to go through oil seals. That's what the crankcase breather tube is there for; that and to have excess pressure sucked out by the intake pipe's vacuum due to the turbo.
it turned out I was leaking horribly from a pipe that the prev owner "engineered" to fit on the IC and dented the hell out of it so it didnt seal what so ever on the silicone coupler. I took it off and looked thru the pipe and saw ALOT of light thru the coupler
I fixed it tonight and another small spot and the car picks up much better.
Also its running rich as hell.
BTW, I dont think any air should be getting into the crank case honestly. Much shouldnt be getting past the throttle plate.
I ran like 40psi thru tonight with no leaks now.
