???Does the new HTA Green hold boost like the RED???
Taper is a function of max flow compared to RPMs. In general, the higher the RPM, the more air the motor can ingest. The MASS of air the engine uses goes UP, but the boost pressure (air backed up waiting to go into the motor) goes DOWN. In general, smaller compressor wheels provide lower air mass delivery (measured in lbs/min.) than larger compressor wheels, so I would not expect that the new GREEN HTA would match the larger RED HTA's output. The amount it would taper, if at all, would depend somewhat on the capabilities of the motor that it's mounted on to flow air...
Right, on a built motor I wouldn't hesistate for a second to but a .82 or 1.06 HS on it. I heard subie guys have a lot of problems with FP, I am surprised you guys don't say the same, especially with all the FP Threads I read. If it were me Id go with a GT42 Turbo with a 1.06 HS, but thats just me. If he's looking for moderate levels Id go with a 30R or 35R.
In contrast, a GT42 is HUGE, and would not satisfy 99% of the people considering a Green or a Red. Not remotely in the same ballpark...
As far as your comments about FP, it sounds like you've had no experience yourself. There are thousands of very happy FP customers here, myself included, who would be pleased to give you the benefit of our experience. FP makes great products, and stands behind them. What more could you ask?
sikwititevo9
Aug 22, 2016 06:14 PM
STWHY?
18
Jan 17, 2010 08:59 PM
