Replaced TC, found a leak, replaced o ring and seal....still leaking!!!!!!
Why I still own this car, perplexes me to this day.
Well, in my NEVER ending chase to track down a noise, I wound up replacing my transfer case with an 04 RS unit that was rebuilt by TRE.
When I first installed it, I noticed a small leak about the size of a quarter every time I parked the car. So I bought the O ring, and a new seal, and replaced them today.
I thought I had it all figured out, got it out with out having to drop the sub frame again, so I was happy. But, when I got home, I noticed the TC was leaking again.
I did not pinch anything when I put it in, it went in with out a hitch. What the hell am I doing wrong?
Please help, because three quarts of AMSOIL trans fluid and a quart of AMSOIL SVG are not cheap, and I know i'm gonna have to do it again.
![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
I inspected it real well. Did not see anything out of the ordinary.
It was looked over and rebuilt by Jon at TRE.
I'm stumped. Again, this is leaking between the TC and where the trans meet. I used to overfill my other TC and it never leaked from that. So I ruled that out.
Okay, I guess i'll just talk to myself. lol
I guess the only thing for me to do is pull the tcase again this weekend and inspect the "shaft" that the oil seal goes on. I imagine the smallest burr, or imperfection will cause it to leak right passed the seal.
I swore I checked it over real well when I pulled it last, but I guess not.![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
So, i'll do that this weekend and take pics of it and see what happens.
It leaks between the trans and the t case, the only thing that is there on the drivers side of the t case is the seal and the o ring. I've replaced both too.
I may just fill it on a bench with the seal in and the shafts in to see if it leaks just the way it is.
I ruled out the breather on top because it was intact and it leaks with out even moving.
Yes, I am talking to myself.
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
The o ring is not suspect, but the seal is. The seal is what keeps the T case fluid in, not the o ring ( IIRC). So I gotta check that "shaft" real well that the oil seal slips over for any oddities.
I thought the o ring was for the trans.....
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
And sblvro, I don't think it is, because I had no issues with my old tcase, just this new one.
There is a third seal between the tc and the gearbox, a small o-ring (MD743612) on the oil return pipe. Be carefull, the front diff is lubricate by the gearbox oil, the crown pinion is lubricate by the tc oil. A leak between tc and gearbox is surely gearbox's oil.
This tc is a non acd one but it's the same thing.
I was told that the o ring for that location is only for the ACD equipped Evos. Please correct me if i'm wrong. I just want to have all my eggs in a basket before I pull it out again.
According to my parts printout for an 04 Evo with out ACD, it is not listed. The only two that can be suspect are the oil seal, and the large o ring. Both of which are on the drivers side of the case that mates to the trans. Parts # 4 and 3 in the diagram.
![](http://i35.photobucket.com/albums/d169/Revvin9k/PICS1635.jpg)
If my t case is leaking from there, is there anything else I need to be looking for? Aside from those two items?
Sorry for the barrage of questions, but I am getting really sick of pulling this damn thing.
Wow, thank you ever so much for the info. I went to my local mitsu dealer and ordered, the oil seal, the larger o ring, and the one that you pointed out. Hopefully it cures the leak. I'm going to go over it real well just to make sure this is the last time I pull her out.
Thanks for all the info.
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
