JE Pistons Pro Series FSR Forged Pistons 22mm pin 4G63 DSM
Anyone have experience with these new pistons from JE that are standard bore for the eclipse, (I have an Evo III).
I currently have some 85mm wiseco installed and want to know if any boring would have to take place to put in these new ones.
How many miles on the engine? It's probably necessary to bore your block to ensure that it is straight/round. A quick inspection after disassembly will let you know. If you need to bore the block, they also have .020" oversized pistons too.
I know several people running these new parts and they are very happy.
What material are your pistons made from?
We use two different materials, 2618 & 4032. 2618 is used in most of our severe duty / power adder applications. It requires slightly more piston to wall clearance and can stand up to the abuse of a power adder. 4032 is used for applications that are more on the mild side. 4032 has less of a expansion rate which allows us to use it with tighter piston to wall clearances. This is great for direct replacement factory pistons.
The new fsr pistons are 4032. If you want that material for lower HP use the Mahle cannot be beat for quality. I have used every piston out and the quality of the Mahle is tops.
I have 200,000KM on the car.
At about 160,000 I built the bottom end with Wiseco pistons 85mm and eagle rods, however, the rings took a blow this weekend (they have been getting a lot of abuse over the past few years)
Reason I dont want to bore my block is because where I live, in the Cayman Islands, we don't have good machine shops at all.
Should I just go back with Wiseco pistons then?
Yeh honing the block is no problem. My mechanic has equipement to do that.
What I just want to avoid is going to the machine shop to get the block bored for an oversized piston.
Those new JE standard bore ones look promising though, I really think I'm going to get them.
If not, bore AND hone the block and go with these .5mm oversize:
http://www.amsperformance.com/cart/J...0-Pistons.html
http://www.jepistons.com/Catalogs/Sp...bishi/evo.aspx
•Crown requires no deburring or preparation
•2618 T6 high tensile forged aluminum
•NEW ASYMMETRICAL FSR forging! State of the art asymmetrical skirt technology reduces friction and mass while providing a more rigid and durable platform (Skirt Style F).
•In this environment, higher boost levels or heavy nitrous usage necessitate JE's wrought 2618 alloy.
•FSR pistons include offset pins for quiet operation.
FS[SouthEast]: JE Pistons 85mm bore
hutch959
23
Sep 12, 2016 05:17 PM
jameswwt
Aug 30, 2010 01:15 PM
