Kellford 272s
Kelford 272s
Fellow Kelford 272 owners, i'm having a situation where since i've installed these cams, i have had all sorts of issues to keep my car from stalling while @ idle.
I'd like to know if anybody on Stock ECU is sharing the same problem?
I'm about to make the drastic decision to go AEM just b/c i know that with AEM u can have JUN cams and the AEM will put those cams on a leash while @ idle.
Correct it idles 100%, 1 minute then the next dies down to 500 rpm then the car makes the decision of either dying or flying up to 2000k rpms
- Timing at idle 9 degrees from 0-40 load and 0-1000 RPM
- Set and rescale your idle tables like I've done.
Better image added.
Better image added.
