Buscher Boost Controler
My buddy bought their manual boost controller. I just want to know, does loosing increase boost or decrease it, i can't seem to get a straight answer. Such a simple thing but there’s no labeling on this thing which way to turn it.......not like my Hallman
I went through the same question with mine. I turned it all the way in and buried the boost gauge in about .5secs and scared the **** out of myself. Then I turned it all the way counterclockwise for less boost and worked it up from there.
Former Vendor
Don't go counterclockwise on it too much otherwise it will open on you.. and you might lose the spring and ball inside. It's very tricky to get it aligned again. Often the spring doesn't sit well on the ball and you'll be pushing 30psi no matter what setting your on. Just a warning.
