Exedy twin disk issue
I recently had an exedy twin disk HD clutch installed on my 05 GSR. It worked like a dream for about 700 miles, then one day just cruising up to a stop light the pedal goes to the floor. So, I figure dead slave cylinder. So I check it and it moves as I would expect it to only now when I press the pedal in it feels like something is blocking the pedal from engaging the clutch. I have the guy that installed it come by and look at it and he says that a retainer clip holding the the throwout bearing has broken off and that because the clutch is a pull type it will happen again unless I buy a conversion kit from AMS to make it a push type setup. That is another $1200, yikes. Have any of you experienced this issue?
https://www.evolutionm.net/forums/ev...vent-clip.html
Plenty to read there but once you have the retaining clip fixed, get the turbo trix clutch fork stop then never worry about it again. It runs about $100.
Andrew Ferrer
Feb 7, 2017 01:11 PM
Illrunya
Apr 7, 2011 01:03 AM
