innovative lc-1 help plz~!
I just totally installed my lc-1. Finally
But everytime i turn the ignition on it blinks E 2 (error 2)
Then goes through the heater calibration. EVERYTIME
I can not figure this out anybody know where i should look. Or do??
Thanks
Thanks
It goes through the entire heat up session like normal.
Goes to 20.7-9 with the % highlighted. Then goes to AFR reads anywhere from 2.5 to 6.0 and then either freaks out and goes to -.-.- or just goes to -.-.-.
When doing a free air calib. Should the guage read difft numbers? like swing from the right to lean.
All mine does is stay around 20.7-9 and blinks "o2".
I dont know whats going on. But i need help lol....
Not sure if you got a manual but I'd refer to this if you're having problems... http://www.innovatemotorsports.com/s...C-1_Manual.pdf
bah, i hate my life. Guess ill just save up for aem.... god damnit!
is aem way easier then this one?
(not that it was hard but it just doesnt want to work lol)
The o2 sensor for your innovative is cheap to replace and will last 3-5 times as long as the AEM o2 sensor(that will cost you ~$80-90.00 to replace) every time it goes bad. The innovative sensor is from a Turbo VW beetle and online cost aprox. $60.00. I am on my 2nd one in 4+ years and I know people who go through that many AEM o2 sensors every year.
My sensor died after 3 years of lots and lots of METH and that is the only reason it failed. It must have seen 50 gal's of Meth in it's 3 years. My friends who have the AEM W/B never use race gas and have it over 18" downstream of turbo,in downpipe and installed in the 12:00 position,basicly on top of the pipe. Just my opinion of course just sharing my experiences with my innovative vrs. all the people I know with an AEM W/B.
So on my wiring this is how its what it says it SHOULD be:
White: Grounded to the same ground as blue
Blue: Above.
Black:Calibration wire
Brown:Analog 1
Yellow:Analog 2
Red:Power
Now i noticed i dont have a white wire?
its seriously NOT THEIR.
i even cut into the insolation by the actual lc-1 unit itself.
and its not even their!?????????????
no wonder mine doesnt freakn WORK WTF!?
ARE U SERIOUS?!
So this is my wireing:
Blue-bolted to side panel bolt.
Red-12v ignition
Black/Yellow/Brown-taped off.
so tell me, what i should do besides buy an aem lol..
Blue: Above.
Brown:Analog 1
Yellow:Analog 2
Red:Power
ARE U SERIOUS?!
Red-12v ignition
did u miss the last post i put? how can innovative be a "better" wideband then aem?
When they dont even send me a unit with all the wires attached/even THEIR?
That just sounds like their just thrown together and not even looked over.
i give them a big fat freakn F.
lol
lol
Instead of whining on a forum about it, you should contact Innovate or the vendor you got it from; I installed my LC-1 over a year ago and it has worked flawlessly and yes it came with all the right wires. Read closely, make sure you didn't set anything aside or leave it in the box. It's not complicated just make sure you read the directions and follow them to a T. The grounding is the most important part.
its all good, besides it was only 70$ lol.
The guy i bought it from musta ripped it out i guess.
Owell, i ordered the aem one.
Live and learn
Live and learn
Blue: Above.
Brown:Analog 1
Yellow:Analog 2
Red:Power
ARE U SERIOUS?!
Red-12v ignition
Blue: Above.
Brown:Analog 1
Yellow:Analog 2
Red:Power
ARE U SERIOUS?!
Red-12v ignition
I know this is an old post.. but as far as I know, the LC-1 has two version. I think the missing white is perfectly normal. Contact Innovate and they will help you.
mrfred
16
Apr 26, 2008 08:57 AM
