Strange 1-2 Shift Issue
I have an ACT Clutch, stock clutch line, shifter bushings, and a megan short throw.
Last night at the track I did my 1-2 shift and when I let the clutch out and it just free revved and bounced off the rev limiter. I looked down and it was in gear so I pushed the clutch back in and let it back out and it finally grabbed. I thought I maybe heated the clutch up too much on the launch so I just quit for the night.
Later that night I was giving a ride for my friend and just driving around I did the 1-2 shift really fast again and same problem. Goes in gear, clutch comes out, and nothing. Then is perfectly fine like 5 seconds later.
Anyone else have this problem when they speed shift?
I've had a slightly different problem. But mine the clutch stayed pushed on the floor until I popped it up with my foot. This was the day after I changed my clutch but I never unplugged the slave cylinder line.
That happened only once. Then later I changed the clutch line and removed the restrictor pill. Everything was fine till I adjusted the clutch pedal (shorter). I launched the car and the clutch pedal didnt come back up all the way (to its shortened length), it came more like half way up to the adjusted point. So I pushed it up with my foot and adjusted the clutch pedal a little longer. Also clutch pedal free play felt a little too loose when it was short, i could wiggle it in and out about a few millimeters freely before tension was felt but after adjusting it out a little that free play is reduced/gone. Later I did another launch and everything was fine again.
I did bleed the clutch, but I think I might have to bleed it again. I'd suggest bleeding your clutch line.
bluedemon199
Jun 16, 2017 07:22 PM
bbong
Jun 11, 2017 05:25 AM
Thomas Estlick
May 14, 2016 10:19 AM
