Tranny & Diff Fluid Choices...
Ok, I'm having my tranny and diff fluids changed out very soon and I'd like some recommendations as to what to get. Now, there should be 4 things that need to be changed, if I'm correct:
Transmission - 3qts GL-4 75w90
Transfer Case - 1qt GL-5 90w
Center Diff - 1.5qts
Rear Diff - 1.5qts
I've heard Redline, BG Syncroshift, and Royal Purple mentioned the most. Pros/Cons?
Any input as to where to get them online as well. I will be looking locally too.
Rear Diff - 1.5qts
The transfer and rear diff are both just over 1/2 quart each. I think the manual claims 0.57qts. There is no separate center diff fluid, it's just in there with the tranny.
Get 3 quarts Redline MT90 for the transmission/center diff and 2 quarts (total) of Redline 75W90 for the rear diff and transfer case.
WRC4ever: Sure can. In fact I used Amsoil Series 2000 75W90 in my rear diff because my local shop didn't stock Redline 75W90 (though they did stock MT90 and the Shockproofs).
My car is a bit of a fluid mutt with MT90 in the tranny, lightweight shockproof in the transfer, and the Amsoil in the rear diff.
http://www.bestsyntheticoil.com/amso...-gear-lube.pdf
Regular Amsoil 75w90 or Series 2000 75w90 all the way!! Approved for limited slip diffs.
A lot of our rally cars use the Amsoil lubes... the mechanics rave about it.
Originally posted by 5StarSuzuki
I have BG Syncroshift in the tranny. Most DSM shops don't recommend MT90. I have ShockProof on the floor waiting to be changed...
Also got a pm from a guy that metioned omega gear oil... said it stopped the decel noise on his evo V (I think it was a V). So I may try that.
And who are "most" DSM shops?
So it sounds (excluding 5Star's post) like Redline MT90 for the Trans/center diff, and Amsoil Series 2000 75W90 for the rear diff / xfer case are the way to go. Yes?
Hey all,
First, MT-90 works well in the transaxle, since Mitsubishi specifies a GL-4 fluid, which MT-90 fulfills. Perhaps the DSM tranny doesn't specify a GL-4 fluid, in which case MT-90 would not be a good fit. On Nasioc, people reported bad experience with MT-90 in the WRX, but the WRX specifies GL-5 fluids for the tranny.
Anyway, I used Redline MT-90 in the transaxle. The transfer case and rear diff specify a GL-5 fluid, so I used NEO RHD. This is what I used in my wife's WRX and many on Nasioc reported good results with it. It's spendy, about $20/quart. Anyway, I'm happy with the results. Improved shifting action, smoothness, and decreased decel noise. I replaced fluids at ~3500 rpm, and I'm looking to do it again at ~10K miles with the same fluids. I did have a fair amt of metal debris on the magnetic plugs, and I'm hoping there is a lot less at the next change.
Take care,
FB
Take care,
FB
