miss fire
Old Jul 29, 2009 | 06:00 PM
EAS-PA's Avatar
miss fire
I have an 06 evo 9 with light bolt ons that I bought about 3 monthes ago, it has been running fine but it has started miss firing at WOT rite around full boost the car runs fine just driving normal. when it first started it would do it all the time now it seems to do do it about 50 percent of the time i changed the plugs so i know it cant be fouled plugs. any help is greatly appreciated thank you
Old Aug 6, 2009 | 01:49 PM
dantegra's Avatar
Do you have a deleted cat?
Old Aug 6, 2009 | 05:25 PM
EAS-PA's Avatar
yes
Old Aug 6, 2009 | 05:28 PM
YzBrad99's Avatar
Did you make sure all 4 spark plugs are properly sparking? Or did you just change plugs?
Old Aug 6, 2009 | 06:07 PM
bambooi's Avatar
Which plugs did you get? You need to check their gap.
Old Aug 6, 2009 | 06:32 PM
EAS-PA's Avatar
i did only change the plugs and i used factory plugs gaped to.023
Old Aug 7, 2009 | 11:05 AM
20gmr's Avatar
Im in hershey If you want I can give you a hand with it...... could be a plug wire, or coil pack. Plug wire is pretty common because you have to be carefull and only pull on the rubber boot when you remove them, found that one out the hard way.
I am located in hershey right off of 283 and I have two evos, so we can swap some parts to see if that fixes the problem
Old Aug 7, 2009 | 01:48 PM
EAS-PA's Avatar
I appreciate everyones help, I changed the wires and it has stopped so I guess that was the problem even though there was no visible dammage to them. Thanks
Old Aug 8, 2009 | 05:19 AM
BLKCarbonEVO's Avatar
Nice to hear that! See the forums do pay off
MRLancer05
Jul 27, 2016 04:52 PM
moyassine
Feb 21, 2016 11:54 AM
4drboost
AEM EMS
13
Oct 29, 2012 01:38 PM
Emperor 4g63
19
May 12, 2009 12:31 PM
LithiumX
Oct 17, 2007 01:29 PM
