HKS gt30r manifold cracks
My car came with an HKS Gt30r turbo kit. I took off the HKS heat shield and discovered at least 3 cracks in the manifold. The manifold is a t3 flange, and Im looking for a replacement.
Which manifold would you recommend for replacement. Im not afraid to spend money on quality and I dont think I could or even want to get the same manifold.
I just hope I dont have to modify the IC piping or downpipe. Are most manifolds set up at stock position?
The manifold needs to have a t3 flange and have an external wastegate option. this is the only pic of the engine bay I have atm, and will have a pic of the damage shortly once i find my camera
I was checking out this manifold. Im not sure which size wastegate I have (38mm/44mm?). Or are they all the same?
http://www.extremeturbosystems.com/p...duct_info.html
I have a replacement HKS 3037s manifold that I just had ceramic coated for sale if you want it. Your only other option is to have a shop custom make you another manifold. It would also be a good investment to have a shop make a turbo support bracket for you that connects from the hotside of the turbo to the engine block...that's how I have mine set up. This will help prevent futire cracking. PM me for price if you're interested. Here is a pic of the manifold:
Mine cracked in exactly the same spot. Got it welded heat treated and 12 laps on track cracked again at #1 cylinder. The pipes are soo thin. Its really is a piece of s#$t!!!!!!! I'm getting a custom one made up at the moment. Because of the wategate setup your f#$ked either way. I really regret buying this kit now.
Go with the RRE/HAFE cast stainless for durability if you want t3. Otherwise the flavor of the month is these red/bbk etc turbos based upon stock manifold. I would just get the hafe and keep your turbo.
The manifold will drastically resist cracking if you use the turbo support bracket that HKS supplied in the later kits. It connects the turbo to engine block from the hotside and really does a good job at taking the weight off of the manifold. I highly suggest that everyone who uses this kit invest in this bracket. Not saying that the manifold won't/never crack, but it definitely helps a lot. In the last pic that I posted above you can see the bracket connected to the hotside of the turbo.
Mine has the bracket and still went.....twice. Aparently this is how it should work.haha
http://www.youtube.com/watch?v=scDGg...eature=related
