How Choose correct main / rod bearing size?
crankshaft O.D...outer diameter
I would think you would be ok with a standard bearing, if nothing is touched. If you have a mic you can measure the crank and a dial bore gauge to measure the saddle. But, in my opinion, if your this far off you should take it to someone. Or buy plasti guage. It seems beginner friendly
