Thinking about upgrading turbo help !
Okay the time has come where I am looking to upgrade my turbo on my 06 9. I have already done all the bolt on's, I want something that is going to maintain good daily drive ability, and be absolutely trouble free. I have done some homework on the green and red, but still dont know much about the set ups, anyways any suggestion?
Will you be running the car strictly on 93 octane pump gas? Do you intend to do any competiton?, or is it strictly street? Stock cams? Ported TB, IM, exhaust manifold, O2 housing? Catalytic convertor? How much of a power increase do you hope to attain fronm the turbo upgrade? Are you running a larger frontmount?
well I will be running 93, dont have plans to race at track, or use race gas, or even switch to e85. I have the following done to date. I am not running a cat, I am looking to make like 450 with the turbo upgrade.
AMS TBE
AMS FMIC
AMS LICP
K&N filter drop in cone
Megan 02 housing
planning on doing s1 cams.
AMS TBE
AMS FMIC
AMS LICP
Megan 02 housing
If you indeed have an O2 dump then that means that your 3076 would be configured with a gated turbine housing. I don't think so....Unless you have the ATP douche-tech setup.
For a shot at 450 Mustang on 93 with a bolt-on turbo upgrade on an VIII you may want the Red. Still you would need to spend ultra-hours with the tuning Guru. And the S1's may not be sufficient.
If you want 450 Mustang on 93 from your VIII through the factory MAF with S1 cams then you may need a 35.
450 puts you out of reach of obtaining your goal using a stock frame turbo with the mods that you have and plan on doing, s1's. you would definately have to think around a 35 but you can say good by to having fun on the street with that turbo and hello to lag. look at the bright side you will probably get better gas millage since you wont be in boost all that much.
i recomend looking at the bbk full and expanding your mod list a little. you will end up with a great car that is fun on the street and has a broad power band.
oh and just a heads up you will need a new fuel pump and injectors as well no matter what turbo you choose
jeff
jeff
Yeah, Jeff! This guy sounds like a made-to-order BBK-Full customer. Probably he should upgrade the S1's to S2's and port the turbo, TB, IM, exhaust manifold, and etc. He would have a 430 WHP pumpgas rocket. If he is willing to give up 400-600 RPM of spool then he might be able to reach 450- 460 with the Red though.
jeff
jeff
dont fool around with any of these backyard turbo places, and their funny names... lol stick with forced performance they make the best turbos on the market by far. Look over all the dyno sheets that alot of guys have posted up in the dyno tuning and results section and that will help you understand a little more of what you will need to help reach your goals.
https://www.evolutionm.net/forums/ev...ock-motor.html
https://www.evolutionm.net/forums/ev...-red-93-a.html
https://www.evolutionm.net/forums/ev...93-octane.html
https://www.evolutionm.net/forums/ev...ftlbs-e85.html
and the list could go on and on...
