anyone have any problems with high flow cat or cat delete?
Old Oct 13, 2003 | 07:51 AM
Scot's Avatar
I am trying to remain warranty friendly. I would guess if they say a test pipe, that would be a reason (lame reason, but..) to possibly try and void some part of my warranty.
Anyone have any boost issues or problems with a high flow cat?
I am hopefully getting B&B exhaust with high flow cat (i think).
at least the cat would be there vs a test pipe.
Old Oct 13, 2003 | 10:12 AM
sccavee's Avatar
Are you planning on getting some type of boost controller? A 3" turbo back can increase your boost.
I don't think warranty would be a issue (could be wrong) but legal could be. Most states you are not allowed to touch a factory CAT for 3 years or you must have documentation to state damage to it.
Old Oct 13, 2003 | 10:28 AM
992gnt's Avatar
The dealer won't work on your car without a cat. They (and you) can be fined heavily.
They didn't have a problem working on mine with a 3" hi-flow cat on though.
Old Oct 13, 2003 | 12:44 PM
Scot's Avatar
I personally remember problems with GMC Typhoon's if you ran a testpipe.... so I was thinking the same issues may be there with a test pipe on the Evo......
I will get a high flow cat instead.
thanks
Old Oct 13, 2003 | 02:45 PM
evo_dadi's Avatar
i had my first service done in the dealership and they didnt say anything about the perrin cat-delete that i have on my car.
Old Oct 13, 2003 | 03:32 PM
MuttedTsiAWD's Avatar
Since AWD have emissions every year in Arizona I would be getting a HF cat.
Old Oct 13, 2003 | 05:42 PM
Gruppe-S's Avatar
If the test pipe is not run with a cel fix of some sort, the car, upon throwing a code will attempt to correct the A/F which will cause it to run extremely lean. We have seen an extremely dangerous over 1 a/f point of correction, especially in the 2000-4000rpm range.
Thanks,
Gary
Gruppe-S
Old Oct 20, 2003 | 01:43 PM
VIII's Avatar
what exactly would happen if you were to run really lean, i have a perrin cat delete pipe with the cel fix but as you all know most of the cel fixes from perrin dont work and have ran my car for about 2 months with the cel on, is it bad will my engine produce less power. i have noticed that it smells very lean but i am not sure, any fixes or diy to fix, now i am all paranoid and am afraid i am doing something wrong. i will try to re wire it but it never works, i have re wired it three times. HELP now i am actually really worrying.
Old Oct 20, 2003 | 02:10 PM
Jinu0808's Avatar
Again one last time GET THE ULTIMATE RACING TEST PIPE and you will NOT HAVE a CEL. Dont ASK HOW JUST DO IT !!
NERO_NOVA
Lancer Engine Tech
Sep 21, 2009 03:35 AM
MikeyLeblanc
Jan 20, 2008 02:53 PM
Wicked Evo
Nov 14, 2005 06:40 AM
v8killer
12
Jun 15, 2004 07:49 PM
KZEVO
May 2, 2004 09:17 AM
