How much whp will i make? do reply
Old Aug 19, 2009 | 06:38 AM
mannerism's Avatar
Hello this is Zain from Pakistan. i have bought this stuff and will put in my evo8 soon and send it for tuning. i am listing the stuff all i want is that you people tell that how much whp will i make on max boost? we have 95 octane here and the weather is around 30 degrees.
1.TURBO PRCESSION 6265
2.TWIN SCROLL FULL RACE MANIFOLD
3.FULL RACE DOWN PIPE
4.WASTE GATE TWIN 44MM
5.Precision INJECTORS 1200CC
6.POWER FC DEJETRO
7.SLIM FAN
8.ETS INTERCOOLER
9.CAM SHAFT SET 280 kalford
10.PISTON SET weisko
11.CONECTING ROD manley
12.cometic HEADGASKIT
13.SUPERTECH VALVE SPRING RETAINERS
14.FULL BLOWN TWIN FUEL PUMPS
15.SKUNK2 intake manifold
16.SPRAKTECK IGNITION SYSTEM
17.MAIN AND CRANK BEARING ACL
18.CAM GEARS SKUNK2
19.ARP HEADSTUDS
20.PIPE KIT ETS
21.Hks twin clutch
Waiting for replies
Old Aug 19, 2009 | 06:54 AM
mannerism's Avatar
anybody?
Old Aug 19, 2009 | 07:05 AM
MR Turco's Avatar
1 million.
Old Aug 19, 2009 | 07:07 AM
mannerism's Avatar
@Mr turco. plz dont spoil the thread. we dont have much modified cars here in our country so plz.......
Old Aug 19, 2009 | 07:21 AM
gsrboi80's Avatar
Dude there is really no way for us to tell what power the car will make. Should be good for 500 on pump but you'll have to see
Old Aug 19, 2009 | 07:34 AM
SOEuro's Avatar
what type of fuel do you guys have over there in Pakiland???
im guessing mid 600s with that beastly setup
Old Aug 19, 2009 | 07:37 AM
mannerism's Avatar
the fuel here is hi-octane which is 95 octane.
Old Aug 19, 2009 | 07:42 AM
Blkstreak's Avatar
I think turco is about on point.
Every car is different, how much boost is Max boost? How good is your tuner?
Honestly with those mods I've seen cars make from 400whp to 700whp.
Im gonna go with inside that range, benchdyno'ing is fun.
Old Aug 19, 2009 | 07:51 AM
wevo1985's Avatar
get it tuned and dynoed and let us know. we could say all kinds of numbers and you could later be disapointed when you dont make so much. or it could be the other way around. it really depends on the tuner, software your using to tune, dyno, temps of the air, and how strong the build really is. if its not a good build for motor than you can pick up knock.
Old Aug 19, 2009 | 08:39 AM
mannerism's Avatar
i just wanted an estimated whp
Old Aug 19, 2009 | 08:49 AM
BlueEvo61106's Avatar
I would say no less then 500whp all the way up to 700whp with a good tune!!
Old Aug 19, 2009 | 08:51 AM
AmF_15's Avatar
Close to 500ish if I had to guess.
Old Aug 19, 2009 | 08:53 AM
801bmx's Avatar
That should make great power.
maybe around 600whp
Old Aug 19, 2009 | 08:54 AM
dipsetinallday's Avatar
close to 600 whp with a good tuner.
Old Aug 19, 2009 | 09:03 AM
Tsurugi-san's Avatar
520 wheel horsepower! With peak torque available even when the engine is off and cold!
