Amsoil Manual Tranny MTG vs Amsoil Severe Gear SVG
I'd been running the Amsoil MTG in my 6 speed gear box for almost two years now. While the MTG gives better shifting than the stock Diaqueen, shifting is still not as smooth as I would like. I had been thinking about running the Severe Gear SVG in my gear box for a while because its got a higher film strength and perhaps would help extend the life of my 6-speed now that I'm up around 360 wtq. However, since its not designed for synchro trannies, I thought the shifting would suck with it. Anyhow, I decided to give it a go when changing the gear oil a few weeks ago. Its a bit notchy when the tranny is cold, but once the gear box gets nice and toasty, the stuff gives better shifting than the MTG. Granted its only been a few weeks, but so far, I'm pleased. I'll report back in a few months.
i have had hundreds of customers give me all kinds of different input on the shifting performance of the MTG in their 5spd and 6spd, lots of customers giving me the feedback and saying the same you have noticed, the tranny gets smoother once at or close to operating temp, others saying buttery feel from the getgo.
Both MTG and SVG are 75W-90 Lubes. AMSOIL does not recommend mixing these products. MTG is the recommended lube even though SVG will not cause any problems as the SVG carries the important GL-4 rating. MTG has additives specifically for the Synchro's.
LG
LG
If it shifts better, then it must be working well with the synchros, and as you said, SVG is proven to be compatible with brass. The real test will be how well it shifts three months and six months from now. If its still shifting better than the MTG, then I see no point in using the MTG because the SVG is designed for higher gear pressures.
The newer EVO's that Spec the "Special Fluid" is a 70W-80 which is a match for MTF. I have always recommended the MTG because of the use most EVO's see.
LG
I used a handpump, big long one about the size of a grease gun with about ~2ft of tubing. When I usually did it on a lift that was easiest. Under the car sucking 90wt out of the diaqueen can gave me a workout thats for sure. Not the easiest but it's doable. MTG was very easy as I left the bottles in the sun so sucking that fluid out was rather simple.
LG
