US spec EVO 50/50 torque split? Also another question...
Hey guys I'm new here. I've been a member of DSMTALK for almost 3 years now, and now I'm very interested in switching to either the EVO 8 or Subaru STI.
I like how the 4g63 is easy to work on and the looks of the EVO 8, but there's one major drawback..... it's 50/50 torque split. If I'm wrong please correct me because it would be a pleasant surprise. I understand that the Evo's in japan has always been 40f/60r torque split, abling it to drift, do donuts, no understeer, easier on drivetrain on hardlaunches etc etc.
Last time I was at the Mitsu dealership the salesman told me it's 50/50, and that 04' is the only year the EVO is going to be produced in the US.... True or false?
The STI's most appealing aspect is the DCCD, driver can control the torque split. Say if the US spec has a watered down 50/50 split differiential, can a Japanese spec differiential be swapped in for the 40f/60r torque split?
Thanks ahead.
Thanks ahead.
It's a 50/50 torque split. The USDM evo has a mechanical center diff, however some do believe it's the most 'natural' handling of the Evos due to the simpler drivetrain. Also, the torque split is variable, but only when reacting to traction loss at an axle as opposed to the active center diff. However all the things you mentioned are possible with our evo given a driver of sufficient ability. Also, an ACD retrofit is more or less impossible, so forget about it. Finally, I would drive both cars before deciding that the STi is superior. The Evo has won the majority of magazine shootouts despite its 'inferior' feature set. Also you are going to be flamed for asking your question without searching. be warned.
I somehow have to disagree with you nsnguyen. With a 50/50 torque split the car is "safer" to drive, it's more user friendly for the people that aren't as skilled. You won't have some 16 yr old rich punk going into an offramp hot and lose the back end. However the sporty handling is lost. Without a doubt it is still a very good handling car, but on the track or auto X, even the drag strip, the 50/50 hinders performance.
At this time the STI does seem to have the edge over the EVO. 2.5L engine, DCCD, more power.
PS: Thanks for the warning, but if I get flamed for asking this question, you should be grateful I'm not coming on here asking 2F2F questions, or "what bov sounds the best", or "how can I make my car into a 12 second car"....etc etc. You get the point
Originally posted by MaxR
i wish the usdm evo 8 had a mechanical center diff but the truth is its a viscous coupler diff.
amstel78
20
Nov 2, 2010 06:43 PM
amstel78
Apr 17, 2007 06:53 PM
Meeyatch1
16
Apr 25, 2003 10:59 AM
