got a CEL and Overboosting!!
Hello guys.. I just started my evo tonight and the CEL appeared. Later when I was driving at 6th gear, I stepped on the gas at low rpm and the boost was not that high (normally at 1.2 bar) and then it reached 1.2 bar and went to 1.4 bar for a split of a second then back to 1.2 bar. I dont know what happened I mean it could be boost creap but I checked again at lower gears. I stepped on it at 3rd and at 4th it never went over 1.2 bar.
Is this normal if driving at 6th gear while at low rpm when boost goes higher?
And about the CEL do they come out as a cause of the High Flow Cat or only from testpipes?
Cel lights come up for various reasons. Use a scanner to find out the cause.
You can get cel from hi flow cat.
I went to get a scan for the cel and it was from the idle control. I got it cleared yesterday but today after I turn off the car, the turbo timer was counting down and at that moment, right after I turned it off the CEL came back!
What do you think is causing the idle controls errors? Is it the turbo timer? Its Greddy btw.
nspyr
26
Jun 20, 2017 02:08 AM
740 Turbo Brick
Aug 24, 2016 11:44 AM
