Question about EDM/JDM 7/8RS ACD w/o AYC pump and placement
I am doing some reasearch to move the ACD pump to the rear of the car where the evaporative emissions canister is in the left rear fender. This is where it is mounted in the ROW cars that have ACD w/ AYC. It'll help with weight distribution, put it somewhere more protected, and open up a big space for a cold air duct in to my airbox, lining up with the Varis(style) bumper duct.
I know some of the Evo 7/8RS models had the option of ACD w/o AYC, replacing the AYC in the rear with a LS differential. I am wondering if that configuration used the same pump/valve set up as the ACD w/ AYC cars in the rear, or the USDM pump/valve mounted in the front? If it is the rear mounted pump being the same as the AYC cars, did just block off the ports from the valving to the AYC? Did have a different mounting for the USDM type pump in the rear (I somehow doubt this is the case, though...)?
All these questions go to the mounting of the pump in the rear, and a couple pieces of plumbing. I would rather use OE mounting parts (most of the mounting holes look to be already there, btw...) than a custom garage built piece. I have friends in Europe that aren't heads, but they don't mind scrounging at the breaker's yards, either, for good used parts.
I've searched, I've looked in EDM ASA (not the greatest without a VIN number of an EDM car set up like this...), I've looked in EDM FSMs, and no real clear answer.
Any help appreciated!!!
Gary@MellonRacing
Aug 29, 2014 02:25 PM
ZyBeR
Jun 7, 2007 06:57 PM
