throttle body leaking
i just did a boost leak test and it wont hold more then 10psi without leaking like crazy from the throttle body is this normal, is the throttle body supposed be leaking when you do a boost leak test?? when i move the throttle body lever around that opens the tb plate it slows the leak down a little bit is this the seal inside?? need help please
heres a great how to on changing them out https://www.evolutionm.net/forums/ev...aft-seals.html
i installed the mil.spec seals, and i have no more leaks. the old seals were a pain to remove though
i used the above how to
edit: its a pretty easy process. i did mine at work, and im a computer tech, not a mechanic haha
doing it next weekend cant wait. do you think that i will feel a difference after i fix it?
thanks for all the good info
Every evo I've tested has bad seals, they just plain out suck from factory.
They can be easy to replace but not that easy like people say. Removing them can be really tough on some. Installing them you gotta be smart otherwise you can bend the new ones. I suggest using a shorty screw drive and a mallet hammer once you've lined it up perfectly just give it a good tap. Use plenty of lube lol.
Mil spec rock too.
Mil spec rock too.
