Second gear won't go in
Having a problem second gear won't go in. The tranny has just been replaced due to worn out synchros so it's probably not the tranny. If I shift at high rpms it goes in but if I'm driving normal it won't go in at all. All other gears work fine. Could it be the clutch?
4th goes in no problem. Reverse is a little stiff but it goes in. Checked the engine bay to see if anythings in the way but nope. Strange become sometime it goes in fine and then starts not going in. Could it be the tranny fluid going bad?
What fluid are you using? Does it make a difference if the tranny is hot or cold?
two things to do....
first - check the clips that hold the shift cables in place. If they do not click into place properly the cables can shift up a little bit which prevents you from getting the tranny in gear. It doesn't take much slop for this to cause a problem
second - if there is nothing wrong with the cables, get a solid front motor mount. You wont believe the difference it makes. I have a built transmission and I too had problems getting in to second until I got a solid front mount... it solved all my problems.
Look under the car. there is a motor mount in the cross member. that is the one I believe he is referring to. But if you are having trouble shifting with the car off as well. Sounds like a tranny issue. Just a thought.
I would really check those clips. If you are looking into the car you see the motor mount on the driver side look around that area you will see the shift cables. The clips on them.
also I have issues on my first start on cold days, Hold the clutch in, start the car when I release the clutch it is if the clutch is engaged and it stalls out immediatly when releaseing the clutch, now when I start the second time its fine, I still feel it grab a bit, but it does not stall out.
Insanity Evo
May 31, 2011 05:11 PM
NYC Evolution
May 31, 2010 09:38 AM
mr.almeida
Apr 19, 2010 10:10 AM
