Changing Serpentine Belt
Hey guys, I need to change my serpentine belt, i noticed its starting to crack, i did research on a good replacement belt and bought the Good Year Gatorback belt from autozone..
I want to do the job myself but the how to for it is pretty much a dead link now. how hard is this job? and what tools do i need? any kind of input and direction would be great.
Thanks.
Thanks.
jack the car up, remove passenger wheel, remove tensioner access panel(plastic cover attached to wheel liner) then insert a half inch ratchet into the box section on the tensioner, relieve belt tensioner by rotating, insert a pin ( I use a drill bit) to hold the tensioner. then you can remove the old belt and install the new one. remove the pin and allow tension back on the belt and you should be good to go.
i need help right now please asap! tryin to do it now and i am rotating with a 1/2inch ratchet in the box section but nothing is happening other than the pully's and belts moving. i see no relief on the belt. do u rotate a certain way? and how much relief is there suppose to be?
nvm thanks tho man, i figured it out. had my mechanic buddy come over. i was turning the pulley not the tensioner... failed! but its done now once i figured that part out. will post a how to for others.. i took pics!
Yabdiel Torres
Jun 22, 2017 06:32 PM
sammiek513
Lancer Engine Management / Tuning Forums
Nov 10, 2014 04:55 PM
didalos
Aug 3, 2013 06:00 PM
