Recirc BOV's above 28PSI, info request
Old Jan 9, 2010 | 10:04 PM
  #61
l2r99gst's Avatar
Post up how you installed it.
If you are getting flutter, I assume it's at partial throttle? If so, try not running the c port (the constant boost source). Or keep the c port and tighten the spring with the adjustment screw.
Old Jan 10, 2010 | 12:43 AM
  #62
ronitlancer's Avatar
It looks like my post got deleted or something? Cause I think you're replying to me. I will post up pics tomorrow. And yes mostly part-throttle situations. Especialyl in higher gears, 1st and 2nd gear are much better then 3rd-4th-5th and 6th basically is flutter every single time no matter what, and so is 5th for the most part.
I was told you can't have C-port unconnected? I have C-port connected to my wastegate boost source, and I have A + B connected to my intake mani. B only worked better then A only but A+B seems to be the best. I have messed with the preload adjustment A ****LOAD and I did make improvements but never found a spot that eliminated it more then 50%.
Hope thats all the data you need!
Old Jan 10, 2010 | 01:46 AM
  #63
ErikB's Avatar
I love my APS twin vent. Im on 27psi on E85 on stock 10.5 VIII turbo.
EvoEi8ht
Dec 29, 2015 04:34 PM
cosmicblueGSR
10
Nov 15, 2013 06:20 AM
BaumBizzle
May 16, 2012 08:46 AM
tstevens
Mar 8, 2012 06:08 PM
Tachyon56
19
Sep 22, 2010 08:07 PM
Quick Reply: Recirc BOV's above 28PSI, info request
