Best compression for e-85?
so, im curious if there are any advantages to droping or raising the compression ratio on my e-85 build.
I am doing a full build with 86mm wiseco pistons, eagle rods, l19 head studs, main studs....etc.
Ethanol will tolerate a lot more timing and compression compared to 93 octane. You will pick up off boost power and on boost power. We have a custom made arias 10:1 piston with super h.d. wrist pins for our E85 cars. I know you can even go higher than that. I believe English racing posted a lot of info on this topic just do a search for it. Good luck on your build!
For E85 yea 10.1 - 10.5 is good! A friend of mine is making 714awhp on a 2g eclipse with HTA3582 at 38psi with 10.1 on E85
I made 663 breaking up with issues and 9.0a/f's on 10.1 at 35psi with E100 so yea I say it's a safe bet.
No it doesn't, it just provides so much more torque under the curve that it feels like your spooling fast when in fact your just making more power per psi of boost as the car rolls into positive pressure. Gives her a little more yank down low!
Stinkyevo1
Aug 3, 2015 09:53 AM
JGNERAEVO9
22
Oct 24, 2013 06:55 PM
nismo3183
11
Mar 21, 2013 11:47 AM
Dannievo
Jul 22, 2009 08:56 AM
