what boost controler are you using
I am looking at different manual boost controlers and I can't deside on which one to get. What boost controlers do you use now or have used in the past and how did you like them? Any that you think I should stay away from and why? Any help is great thanks
Location: Killeen, Tx via Fayetteville, NC via Worthington, OH
Started off with a Greddy EBC and it would not boost over 23psi. Switched to a Forge MBC and am boosting 26psi and holding 24psi to redline.
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
I have a Blitz EBC I will be selling that soon and installing a 3 port solenoid. On my red turbo I should be able to hold 28psi to redline
How difficult is the GM 3-port to tune with the stock ecu? I have a hallman pro to install but am considering selling and buying the GM 3-port. Is the main benefit being able to setting boost higher in the mid range then tapper to lower at the high end?
Works almost like stock solenoid but lets you get more psi. You need to tune for it.
Also GM 3port and JDM MAP (or Evo X MAP) you can have a full ECU based boost controller
Just get any boost controller if you will go down the manual boost controller. I got an AMS one I can sell. Just sittingin my garage for a while.
Dejon tool. Best $50 to spend for an easy and quick boost in hp. I rocked it for 4 years without needing adjusting.
I have since switched back to the stock solinoid and a restrictor pill so the cops can't say anything.
hallman pro is a great unit the buschur is one of the worst controllers if ever bought that thing gave me nothing but problems and headaches leaking and constantly backed down......worst piece ever invented imo....
