'03 Evo 8 running warm, possible causes?
I'm new to the board and a friend of mine has me doing some work on his car. The problem is that the car while driving the temperature gauge goes ~3/4 of the way up and comes back down. So I check the oil its fine, l checked the coolant its fine but it seems someone had filled with 100% coolant (not premixed). I'm gonna drain it out in the morning and install a new thermostat with water wetter and distilled H20. He had the Iridium plugs changed at a local Firestone and then this... Kinda fishy but who knows... The car isn't leaking or using coolant just the needle goes up to 3/4 during accelation, and then drops back down.
I know Antifreeze doesn't cool as well and we're hoping that the antifreeze isn't dissapating the added heat from acceleration as well as if the mix was correct. Anyone have feedback or input on this?
![](http://images.ibsrv.net/ibsrv/res/src:forums.evolutionm.net/get/images/misc/progress.gif)
I dont think that is the problem i think your issue is that you need to bleed the system. What i usally do is leave the radiator cap off with the heater on and wait till the thermostat opens and add coolant try that and see what happens.
Sounds like the thermostat. But if you change the thermostat and it keeps over heating it may be the temperature sensor. Also if the spark plugs are not correctly gapped, it will tend to make the car overheat. I suggest pulling the spark plugs out and re-gapping them also.
richardjh
120
Oct 6, 2017 08:58 AM
mda56
E85 / Ethanol
69
Jul 5, 2017 07:52 PM
westmc
Nov 7, 2010 02:57 AM
