Evo 8 Valve Question...
Well, if you haven't figured it out, next time (I hope there isn't a next time) drain the coolant before pulling the head. Also, that coolant that is sitting on the pistons is headed for the pan so you should get the pan drain plug out too.
Got luck with the repair.
lol i tried draining as much as i could without taking out the radiator lol.. didnt work too well
I bet with the timing jumped...ALOT. too bad. i bet you smashed them pistont really bad also.... Thats a engine build... im sorry .
If you removed the belt, then the belt (most likely) wasn't the issue. I doubt the timing was off the whole time cause it would have failed a lot sooner. I'm betting on a failed timing belt tensioner. As far as the bolt backing out of the flywheel. Install error.
As long as the head isn't cracked, it may be fixable. You'd be surprised at what can be fixed.
I've seen heads with gouges in them, trashed seats, messed up guides, you name it. Repaired.
