backfire/popping
Old Sep 27, 2009 | 06:36 PM
italianevo88's Avatar
backfire/popping
I only found one thread and it was 7 years old and not what I was looking for, any help would be greatful.
Well my 03 evo 8 has been backfiring a decent amout and im getting annoyed/ worried, its tuned for the cutout, and backfires a decent amount full throttle between 4000-7000RPM, and im not sure if thats harming it at all, and when i have the cutout closed it backfires less, any thoughts?
main mods for reference: 58mm turbo, 750cc injectors, 272 cams-
Old Sep 27, 2009 | 06:46 PM
X91EVO's Avatar
Registered User
first thoughts.. did you get it tuned?
Old Sep 27, 2009 | 06:48 PM
STiHAVOK's Avatar
plugs?
Old Sep 27, 2009 | 07:12 PM
yeah its tuned by kunal. ill check the plugs tho, whats a good brand of plugs for reference?
Old Sep 27, 2009 | 08:09 PM
darkside4G63's Avatar
NGK brp8es gapped at .028 and you should be good.
Old Sep 27, 2009 | 08:42 PM
STIKILLA1084's Avatar
+1 plugs
Old Sep 27, 2009 | 08:46 PM
mx4life85's Avatar
Mine backfires only when I shift gears with the cutout open at full throttle during shifts. Other than that its pretty good about not backfiring.
herbal77's Avatar
Plugs
Old Oct 1, 2009 | 02:10 PM
is there any other common cause of excessive backfiring? - thanks
Old Oct 1, 2009 | 02:33 PM
Redline-Z's Avatar
Veteran: Air Force
Under WOT, misfire is the easiest cause. Go with the 8's like stated above.
Old Oct 1, 2009 | 03:46 PM
2plaz's Avatar
mine only does it when its cold out and i dont let it warm up
Old Oct 1, 2009 | 04:16 PM
80210's Avatar
Spark Plugs is my first advice.
Old Oct 1, 2009 | 05:23 PM
AngryEvo8's Avatar
Go to napa they will have your plugs vince.
Old Oct 1, 2009 | 06:04 PM
allright thanks everyone
Old Oct 1, 2009 | 06:53 PM
bbyevo8u's Avatar
maybe its fuel thats not being burnt up? do you have a air fuel ratio gauge
do a boost leak test
Quick Reply: backfire/popping
