Need Fuel Pump Help
Need Fuel Pump Help
My friend and I installed my walboro 255 fuel pump yesterday and the car runs fine, but the "low-gas" light is always lite now and it shows that I have no gas in the gas tank? Soon the "service engine" light also came on too, but even so the car still seems to run fine...
I just wanted to ask if anyone knew if these two problems were related and how to solve them both...any advice would be of great help! Thanks!
I had the same issue when I installed mine. There is a small pin or needle that registers up and down with the float. It rubs a kind of metal plate that will register the fuel to your cluster. Not sure why the cel is on though. I would have a parts store run those codes for you.
Ok, so I just stopped by autozone to get my CE Light checked out. It gave me a code of P0463
Saying something like it's probably because my gas meter is not reading correctly (which is true).
I've tried the gas cap and that didn't work. Must really be the fuel indicator that was not put in correctly or is messed up
This guy has another fuel pump assembly if you need one:
https://www.evolutionm.net/forums/sa...ket-parts.html
It is most likely the float device. It can be fragile and cause the reading to be off. As far as the CEL goes I'd disconnect the negative battery terminal and then reconnect. See if it goes off again now that the walbro is hooked up.
