New Turbo, To Cam or Not to Cam? - That is the question
Cams are a great bang for buck. On my old Evo, I gained 65whp (236whp and jumped to 301whp at CBRD) by adding a test pipe, LICP, FMIC and Works 269 cams. I'll attribute maybe 20-25whp to the LICP, FMIC and test pipe. Upgrading the cams is one of the best things you can do to improve power!
I definatly recommend cams along with the BBK. The BBK alone with stock cams still won't dissapoint.
I honestly have to disagree...
if you are doing an aggressive cam (on a IX) with valve springs etc.. then they work well... but your talking springs, install, cams, etc... or a turbo which will generally net 30-80whp depending on the turbo if its stock housing...
evo 8's respond great to cams, the ix not AS much... a good stock housing turbo will net you big gains...
just my opinion..
cb
just my opinion..
cb
