Ways to hold boost at higher rpms
Any high pressure wastegate will still taper to a point.
And why will it help? Are you people running the same setup as the OP? Do you have experience running 28+ psi and testing a MBC vs an EBC and the taper? I'd have a hard time accepting advice to buy a $200+ part from someone who has no experience and can only explain his reasoning with "do a search".
I am on a bone stock engine with ARP head studs and a set of Kelford 272 cams with springs and titanium retainers. Bone stock intake manifold, throttlebody, etc.. I have so many restrictions, I am surprised it is flowing so well.
on my old setup i spiked just over 27psi and held almost 26 to redline. it was a 20g with a forge wg. the turbo was fully ported an i had a megan mani. i also had a stock tb and intake mani. i usedd a hallman mbc
If I can get back to the track before the end of the season, I am definitely going to experiment with a filter vs. no filter. I was thinking of running some dryer ducting directly to my turbo inlet or something like that.
We only have a few weeks of the track open in western NY this year, and I am out presenting at conferences for a few weeks, so it will be tough, but I will definitely see what I can do, and let everyone know what I find
I think we may have a different WGA at the shop, so if we do, I will give that a shot, and do back to back dyno pulls to see if we can do anything to hold more boost.
--mark
--mark
i used to have the same problem w/ my srt-4 when i had stock turbo.... stock boost is 15psi spike and 12 at redline...w/ my wastegate/boost controller i used to put it to 18 psi..then it would go to 13-14 at redline...sooo i put it up to 23psi and it would drop to 18psi after a couple hundred rpm's and then 16 at redline lol. .sooo just jack it to the sky as some one else already said haha..
I would love to have a solution that easy for the Evo, and that is why I want to try the forge WGA
--mark
