ticking noise coming from engine bay somebody help please?
okay so i just bought this evo and when i test drove the car i didnt hear anything wrong with it, and then got it home and i heard this ticking noise after it was warmed up. i dont think its rod knock because i have watched a few videos on youtube and it sounds nothing like that, its like a ticking noise and my dad suggested that it could be the valves?? if anybody has any insite on this it would be greatly appreciated!
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Location: I'm Canadian living and working in Dubai/Kuwait/Bahrain
1 Post
They tick man, question is how badly is it ticking. Go and boost a bit and see if it goes away.
Search ticking noise on here you will find many different opionions
hey guys thanks for all the responces, it just ticks at a steady pace, when i get to higher rpm it ticks faster, also the car has 60k on it and the previous owner was a dumbass to put it nicely and yeah.. i dont own a video camera so i cant film noise.. if you guys have any more suggestions please let me know!
no its stock cam, i have 3"dp, hks hi power catback, injen intake, hks ssq bov, evo 9 turbo, apexi boost controller, apexi turbo timer, and its tuned
and im running mobile1 full syn 10w30 like it says to run
Hmmm, interesting. I also have a very loud ticking noise coming from my injectors and I have recently changed my oil to 20w-50. I didn't know that injector noise and oil viscosity could be related like that so I'll try to find out when I change my oil again.
They Tick, honestly its probly how it should sound. If you want to be 100 percent sure, post up a vid of the car with the hood open and then engine running, that will give people a better idea.
It's most likely just the valves, but it could be a lifter. I'd rather not scare you into thinking something’s wrong with your car when in reality it could be nothing.
yeah everybody ive talked to said its prolly nothing because evos are noisey, im just used to a smooth sounding motor.. like it run very smooth but that noise just scares me.. anything weird like that freaks me out. my buddy is going to adjust the valves for me sometime this week and well see if it continues after this. thanks for all the help guys
you might think this is weird, but you can find a needle stethoscope in most stores (napa, pep boys, auto zone, etc..) and you can put those on and search around for the noise. put it up against the injectors, head, wherever you think until you narrow it down. weird suggestion, but it might help...
My car has almost 85000 Miles on it now and its always had a tick under the hood and I have always thought to me self is it the lifter? Is it a valve? But after so many miles I have givin up and just accepted that evos make sounds lol its like any Mitsubishi.
Try taking a Flat head screw driver and putting frimley against you ear and touch the valve cover above each cylinder you will hear each set of valves and you can go down the and listen to see if any of them are louder then the others and that will tell you if something is wrong. You can also do this for each injector. Its simple and it works great
But remember that motor sounds travel and go a long way.
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
