Mobil 1 FTL!
Old Oct 10, 2009 | 09:43 PM
  #31
Piro Fyre's Avatar
Originally Posted by scumrat
Royal purple put out the most power. The avarage baseline of the test car a 350z was 224 hp/220 TQ . with the royal purple it put down a staggering 242 hp 227TQ/!!! Talk about best bang for the buck.
http://www.tedsoil.com/pages/misc/ro..._vs_amsoil.htm
Royal Purple uses a different chemistry than most oils. They are one of only a handful of marketers using Molybdenum Disulfide (Moly) in their oil. Moly is a solid material, which is specifically banned by Cummins®, due to excessive valve train wear.
HP gains doesn't always mean it's the best. If I was looking into motor oil, I would look into protection and lubrication properties rather then HP gains because I would like to have my engine running instead of clogged.
Old Oct 10, 2009 | 11:32 PM
  #32
iseedipp's Avatar
castrol is very good oil all the ///m cars use it and my m3 was tracked every now and then but was a dd and i t neber burned any oil
Old Oct 11, 2009 | 12:42 AM
  #33
evovin's Avatar
I always use Mobil 1 EP
Old Oct 11, 2009 | 01:14 AM
  #34
Brokenevo's Avatar
I never had a prob in my 500WHP evo with mobil 1 guess I was lucky or my build was better lol
Old Oct 11, 2009 | 01:24 AM
  #35
importjake00's Avatar
Originally Posted by evowario
think with your dipstick jimmy..
Old Oct 11, 2009 | 04:42 AM
  #36
NabiExodus's Avatar
a friend of mine switched from mobil 1 to royal purple in his 06 mr and he loves the stuff, I'm not sure his whp but his car is far from stock and he's had better performance from it since the switch.....I know another person with a built Acura RSX Type S thats turbo'd who runs amsoil and only changes oil twice a year, last time they pulled his motor apart everything looked fantastic....
Old Oct 11, 2009 | 06:36 AM
  #37
apagan01's Avatar
when pepople say i love this that oil i just crack up ! it doesnt mean your engine is liking it one bit.
Look at the testing done, like Volatility test, four ball wear test "this test will tell you how your bearings, rings, crank and cams will wear.
I have seen many times engines being pulled apart small and big runing all types of oils and i can tell you what that you can see the difference in the engines that full synthetics were used, Like that Acura RSX you have mentionned.
people dont get it high quality oils pay off, but i tell you what your engine internals, tranny those components are getting it they will pay you off in a bad way in the end you may not notice it one year from now but you will several years down the road when yoju need new syncros and sleves and bearings because of junk oil or cocktail oil mixes like a lot of them do
JUST MY 4 Cents
Old Oct 11, 2009 | 07:26 AM
  #38
grillpt's Avatar
I've almost always used Mobile1 (I've used Quaker State Q Horsepower a few times) and have never had any oil consumption issues. I've got an 03' with 64k on the clock.
Old Oct 11, 2009 | 08:27 AM
  #39
Liqquid's Avatar
Originally Posted by Piro Fyre
synthetic is synthetic.
THINK WITH YOUR DIPSTICK JIMMY!!!!!! sorry had to
EDIT: fail, 200 people beat me to it
I just switched to Castrol also... 10w-40. I used Syntec back when it first came out on another car, no complaints no smoke or oil usage...
I never had any oil usage with the 10w-30 mobil one actually, but with the built motor now I was starting to use some.
Old Oct 11, 2009 | 08:28 AM
  #40
LI Pinky's Avatar
AMS Oil FTW!
Old Oct 11, 2009 | 08:36 AM
  #41
Piro Fyre's Avatar
It is, isn't it. It's mainly up to the manufactures on how they want to produce synthetic and what preservatives they want to add. It's just the way I see oil.
Old Oct 11, 2009 | 08:37 AM
  #42
SIKEVO9's Avatar
i used Mobil 1 for both my cars since day 1. recently tried the 0w30 Castrol Syntec on my GTI and would have to say im impressed. No oil burning and the car feels more smooth and faster. I will try it out in the EVO next. I heard 0w30 is the European formula thats better then the rest and its actually made in Germany.. Is it ok to run 0w30 in the EVO?
Old Oct 11, 2009 | 10:10 AM
  #43
nightwalker's Avatar
I had a 92 integra that I ran Mobil1 in since I owned it with 45k miles. I gave it to my brother at 350k with the original engine. He drove it until 440k before overheating the engine and warping the block. Only Mobil1 since we owned it.
My Evo has only had Mobil1 since day 1, and it is clocking 143k. It is a daily driver that sees 23 psi and 7000 rpms daily. Still on stock original turbo too. Checked the turbo a couple months ago, and no shaft play. I'm sticking to what works for me.
Old Oct 11, 2009 | 10:26 AM
  #44
TTP Engineering's Avatar
Amsoil Racing Dominator here.
Old Oct 11, 2009 | 10:47 AM
  #45
gsrboi80's Avatar
M1 EP mostly. 120k of hard *** miles and it's all thats ever went in the car. No consumption. I'll stick with what works until the bottom end is built then I'll use the builders recommended oil.
M1 must be doing something right cause for 120k I have not been easy on the car.
Little OT but the fluids that have got me 120k hard *** miles. Stock block, Stock tranny, Stock TC.
Engine: M1 EP mostly sometimes the regular (No Zmax, Restore 4,or any additives ever)
Tranny: Penszoil Syncromesh
TC: Diaqueen
Rear Diff: Diaqueen
My 2 cents
Quick Reply: Mobil 1 FTL!
