help-ignition break up with 30psi
Hey guys i have an evo 8 tuned to 28psi- i hit 30 yesterday due to the cold weather- In full boost the ignition starts to break up as if i need new plugs--maybe i do- i changed them before the tune
i have a coil pack setup wich i was told should fix that problem
-any suggestions would be great!!
-mods
gt30 turbo kit
880 injectors
meth kit
fuel pump
other supporting mods
-mods
gt30 turbo kit
880 injectors
meth kit
fuel pump
I had ignition break up as well but i had the HKS DLI system. I had to switch over to a coil over plug setup and never had the issue again. Plugs can be an issue as well.
Sparktech has a new setup out for more daily driven cars that is proved to hold up to 600-700 whp....
Might wanna look at going coil over plug to truely eliminate the breaking up issues at high boost.
401tuner
13
Jan 21, 2009 07:27 AM
Lucas English
41
Jun 11, 2007 01:24 PM
