Balance Shaft Vibration , Help !
Old May 27, 2014, 06:49 PM
EvoTurboTurk's Avatar
Originally Posted by 19DB794
There's a simple way to make sure your balance shaft is set properly. You simply rotate it and if it falls away from the timing mark when you let go it's not correct. If it falls towards the timing mark, it's good.
Is there much of an improvement in driving with the timing set correctly?
Old May 27, 2014, 07:33 PM
lostsoulsevo's Avatar
Um......yes lol
Old May 27, 2014, 09:30 PM
Originally Posted by lostsoulsevo
Um......yes lol
Haha perfecto!
Old May 28, 2014, 03:34 AM
19DB794's Avatar
Yes, there's no vibrations what so ever. I've never experienced it myself but I heard it feels like a mini earthquake lol.
Old May 28, 2014, 05:34 AM
Lol it actually does feel like a mini earthquake, I wish these motors never had such a problem like this. I love Evos & the motors, its sad to see engine failures due to these problems... Evo for life <3, I reckon best car & engine ever invented.
Old Jul 10, 2015, 04:57 PM
kaj
kaj's Avatar
Bump for clarification.
Which balance shaft¿
I used a screw driver to ensure the oil pump wasn't 180° out.
Both balance shafts were lined to timing marks.
The balance shaft doesn't run on a gear, so can't be 180° out like the oil pump shaft, correct?
I did everything as I normally do with the timing belt change, but car idles pretty rough (logs look fine).
Just checking all avenues.
icole
Oct 21, 2016 01:20 PM
bakuro117
Aug 29, 2016 08:43 AM
STM Tuned
31
Feb 9, 2016 06:12 AM
Pal215
Aug 26, 2015 03:43 PM
Olms2468
May 14, 2015 05:48 AM
Quick Reply: Balance Shaft Vibration , Help !
