JohnBradley's 2.2 long rod build
Old Nov 9, 2009 | 10:17 PM
  #136
migs647's Avatar
EvoM Community Team
Did I mention I get dibs on the first ride in it?
Old Nov 9, 2009 | 10:23 PM
  #137
BLKCarbonEVO's Avatar
You can surely have the first ride but I want the first ride where Aaron can actually "boost" it!
Old Nov 9, 2009 | 11:45 PM
  #138
R/TErnie's Avatar
me want ride in really fast roller coaster.
The great thing about this roller coaster ride is there is no minimum height requirement!
Old Nov 9, 2009 | 11:48 PM
  #139
OMFG I think I saw Aaron on Little People, Big World two nights ago...
Old Nov 10, 2009 | 12:55 AM
  #140
JohnBradley's Avatar
We ran into them at PIR one year when he was running his Bug at the Bug meet actually.
Needs at least 50 miles on it and then it will go to the dyno. There are bound to be some bugs so I dont want to find them on the dyno in the middle of a pull. It'll get the sweet triplecheck in the next few days and then we'll see.
I am gonna have to charge for rides...that way when I get the ticket least its semi reimbursed.
Old Nov 10, 2009 | 01:32 AM
  #141
yahu's Avatar
That porting work looks nice! Did Jeff do that, or you, or did ya'll tag team?
Old Nov 10, 2009 | 12:28 PM
  #142
It was initially a tag team, then Jeff finished it up cause he had "ideas" for it. I did the bowl work and opened up the intake a little and smoothed that. Jeff went over the exhaust and got nuts, and then checked the bowls as well to make sure it all was what he wanted it to be before he signed off on it.
Old Nov 10, 2009 | 12:30 PM
  #143
Fuel system is more or less done (save the -6 return) so here are a couple of pix to show how we did it. Basic stuff, not too exciting:
Old Nov 10, 2009 | 01:17 PM
  #144
RSMike's Avatar
sweet injector setup!!
Are you running long injector nozzles that actually protrude into the runner?
Or will short nozzles work ok from that height?
Old Nov 10, 2009 | 01:21 PM
  #145
Looks dope Aaron! I'm so excited about my build in the Spring. I have some pretty cool things I want to do. Eric likes to brainstorm!
Mikey
Old Nov 10, 2009 | 06:56 PM
  #146
yahu's Avatar
That injector setup is just wicked looking, Aaron.
Old Nov 10, 2009 | 07:55 PM
  #147
Thanks guys
Its funny you should mention that because I have had the primaries in both locations to see the effect on power/torque and drivability. It doesnt work with the primaries in the upper location actually. The car would not idle, did not transition well through idle to cruise and made 8whp less at the same boost level.
When I started this build there were no options for an injector that would run well on gas and E85 that would support 800 whp without some pretty large sacrifices. So last year I got one of the first dual rail Magnus intakes with the idea that the stock computer would run the main for and I would use some sort of add'l injector controller for the other 4.
Then came the ID2000s and the FIC 2150s (or the so called 2400s) and then 4 injectors and 800whp was significantly easier and would work on both E85 and gasoline. They work so well I can actually idle them with the O2 feedback on at normal base pressure with no issues. With the higher pressure as I pointed out they will still idle and drive but I have to set it all to open loop and tune it that way.
Aaron
Old Nov 10, 2009 | 07:59 PM
  #148
JesseB's Avatar
Too funny on the injectors lol, i actually finished my 8 injector manifold about a week before i heard about the ID2000's lol...oh well.
Build looks badass!
Old Nov 10, 2009 | 08:01 PM
  #149
R/TErnie's Avatar
Aaron,
Put that cam cover on! you have too much money in this thing to loose it over something stupid falling in there. You can take it back off when you're at the dyno
And secondly check your Aeromotive regulator top with the npt barb in it to make sure that the spring doesn't contact the NPT threads on the inside of the regulator top.
Looks amazing Lots of fun. can't wait.
Old Nov 10, 2009 | 08:07 PM
  #150
The cover is going to go back on to drive it. I am thinking of playing with the cam timing a little possibly on the exhaust side depending on how things work with the MIVECs increased range. I have it off to look BA right now is all
oh and call me at the shop or my phone...I'll answer.
Quick Reply: JohnBradley's 2.2 long rod build
